2G AC condenser grommet replacement
Justin DuBois
DSM Wiseman
3,426
3,426
Aug 15, 2019
Oakland, California
I found these grommets crusty and ripped in half. I guess the AC shop had issues they neglected to tell me about.
Anyone know the part number?
Anyone find a replacement?
I am not at the body shop right now but could likely later look in CCC one and figure out what the oem part number is for it. That is the two rubber isolators that mount the condenser correct?
correct, when complete with the nut hidden inside, the bolt and washer pull it snug on the c shaped hole in the condensor bracket.
I'm having similar troubles finding info on these parts. My car had the AC removed when I got it, so I've ordered a new condenser, but of course it doesn't come with the rubber mounts. Even if the car DID have a condenser in it, the rubber would likely be deteriorated and trash at this point. I've looked in ASA, but it only lists the condenser assembly as a single part (MB899040) and the two bolts that secure it to the upper radiator support. If there's separate part numbers for the rubber mounts, I'll need someone's help who's got a better/more knowledge of the OEM part numbers.
