ABS to ECU pin, Wastegate solenoid delete
The ABS has its own ECU, there's no pin on the powertrain ECU for it that I've ever seen.
And removing the pin for the BCS not only would throw a CEL (probably?) but it'd prevent you from using the BCS as a proper electronic boost controller later in life.
