ABS Light - Key in ON Position
Peepers
120
4
Nov 2, 2002
Toronto, ON, Canada
Ok guys ... quick question here ....
I just did an AWD swap on my Spyder and have yet to start the engine. I was checking to see if my low level fuel light comes on and it does - great! However I noticed with the key in the "ON" position that my ANTI LOCK (ABS) light is on. I'm wondering does the light stay on with the key in the "ON" position and then turn off when the car is running? Or do I have a possible ABS issue that I need to look into further?
Anyone?
Thanks
Easiest thing to do is check the relay under the hood. I pulled mine to kill power to the ABS pump, and the light stays on constantly after doing so. If your relay is bad, then that could be the issue.
