ABS leaking
SiX_BoLt
Apr 28, 2005
Morganville, New Jersey
heyy guys wats up?? i recently just got a 91 gst and i luv it so far except for one problem.
The abs controle module seems to be leaking and obviously not working. the ABS light goes on as soon as i get the car moving and the pedal will go down to the floor and the car wont stop. Under the hood, there is brake fluid on the ABS unit so i thinks thats the first item i should replace, question is, will any ABS unit fit from any DSM or does it have to be from the same model/year?
Thanks, George
I don't know whether you are limited to a specific range of 1G years, but a 2G unit will not work. And I know that there are differences within 2Gs (95 <> 97, for example), so it would not surprise me if you can't use some 1G units. Search a parts catelog comparing part numbers.
- Jtoby
ok will do!! any good online sources that u would recommend?
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
