ABS Delete Problems......
Slow91Laser
233
Oct 28, 2010
Orlando, Florida
Alright well today i decided to attempt deleting my abs system since it leaks and doesnt work anyways.....
I have the correct parts from a donor car so far i have ALL the lines out besides the rears (my problem lines) and since they were pretty much rusted in the fitting they would not come out!
So i had to cut them i went down and bought a flaring kit and cutter when i got home i realized that theres no room on the line to reflare the fitting since it's right on a bend....
Now my question is should i just go to the junkyard and get both rear lines? Also wondering how hard that would be to do im assuming nobody sells the lines anymore?
Any help would be great since my car is torn apart and is my daily LOL.....:ohdamn:
Thanks!
Just take the end fittings with you to a store(1 front,1 back), get new end fittings, and a 25' roll of 3/16 brake line.
Take the old rusty crap out and replace it with worthwhile line. Junkyard lines are junk in the yard. sitting in puddles and rusting, besides you'll bust them taking them out anyways.
http://www.speedwaymotors.com/3-16-Inch-Steel-Brake-Line-25-Foot-Roll,1990.html?sc=WGB&utm_source=GoogleBase&utm_medium=feed&utm_campaign=GoogleBase
I would post up the end fittings if I knew which ones they are,but I don't.
Thanks!
I actually found a place local to me that will make custom SS brake lines so i might just do all SS lines, which is pretty much a cheaper version of the STM kit.......
  • Wanted 6 bolt NT water pipe
    • chrisman287
