3kgt2nv
- 2,024
- 19
- Jan 7, 2011
poughkeepsie,
New York
Engine
- wiesco 9:1 compression pistons
- eagle rods
- acl tri metal bearings
- arp rod and main studs
- arp head studs
- bored .20 over
- align honed
- crank,rods,pistons balanced
- resurfaced block
- hot tanked
- new freeze plugs installed
- new oil pan installed
- new oil pick up installed
- balance shaft removed
- oil pump cleaned and inspected
- new oem water pump
head
- bc 272 cams
- gen 3 lifters
- 7bolt head
- Rebuilt and resurfaced
tranny
- rebuilt trans
- map bearing mod installed
- new slave
- ss hose
- short shifter installed
fuel
- jmf fuel cell
- aeromotive a1000 fuel pump -8 an fuel feed and return lines
- aeromotive fuel rail
- aem fuel pressure regulator
- aeromotive fuel filter
- pte 1200 injectors
- Ngk plugs and wires
Cooling
Mishimoto rad hoses
- Mishimoto radiator
- Mishimoto catch can
- Mishimoto slim fans
- Mishimoto rad catch can
- Nt water pipe conversion with fiav delete
- Water bypass for fiav delete
Forced induction
- 38 mm tial waste gate (dumped)
- Brand new holset 40 pro (thanks Justin)
- Bep 70ar bolt on housing
- Extreme psi oil line filter and oil reducer for turbo
- Erl cast manifold
- 1g nt throttle body swap
- Vrsf front mount
- Hks bov
- jmf intake manifold
- Custom made 4 intake for holset
Electonics
- aem ems series 2
- prosport gauges boost , temp, oil pressure
- aem uego wideband
- aem 5 bar map sensor
- gm ait sensor
- 92 full wiring swap
- 92 coil pack
- 92 cam position and iac swap
- Lightweight battery in custom mount
- Fuel pump cut off switch thru trunk keyhole
frame and body mods
- Custom made solid motor mounts
- Custom partial front tube frame to move radiator forward
- all energy suspension bushings and boost x bushings installed
- adj control arms in rear
- side exit exhaust
Cosmetic changes
- 1gb talon conversion
- Clear timing cover
- Cleaned and painted everything
- Polished aluminum parts
- All new ss bolts and fasteners
- Shaved and painted valve cover
- Partial wire tuck
Interior
- corbeau seats, sliders and harnesses
- competition engineering roll cage
- stock dash and center consol retained
- gutted behind dash
- gutted doors
- gutted rear seat area behind panels
- kick ass air freshener that smells like race gas
wheels
- weld sport 2 piece aluminum rims with slicks
- tbd set of street rims
stopping
- 3000gt big brake swap
- Power slot rotors
- Rebuilt all calipers
- Hawk pads
- 3rd gen master cylinder
- Ss brake lines
- eagle rods
- arp head studs
- bored .20 over
- align honed
- resurfaced block
- hot tanked
head
- bc 272 cams
- gen 3 lifters
- 7bolt head
tranny
- rebuilt trans
- new slave
- ss hose
fuel
- jmf fuel cell
Cooling
Mishimoto rad hoses
Forced induction
- Erl cast manifold
- Vrsf front mount
- Hks bov
Electonics
- aem ems series 2
- aem uego wideband
- gm ait sensor
- 92 coil pack
frame and body mods
- side exit exhaust
Cosmetic changes
- Partial wire tuck
Interior
- gutted doors
wheels
stopping
- Power slot rotors
- Hawk pads
- Ss brake lines
wife found it on
