A few problems. from boost leaks to high idle
azkikr10
330
3
Jan 12, 2003
Union City, California
Okay where to start. I did an intake leak test on my car and found a leak in my tb. i replaced the seals and now it doesn't leak, but my idle never gets below 1000. the screw is all the way down and im out of ideas. i checked my tps and it reads .46 ohms closed no matter where its moved to. I also noticed my injectors had an air leak so i replaced all the groments and O rings but the air leak just seems to be worse. I also cant go above 12psi to save my life. I noticed after i changed springs in my hallman mbc i get 15 vac at idle instead of the 20 vac. I had before. Can someone please give my some ideas on what i should check next? im really suck here. thanks in advance guys.
I don't know what else to try on my injectors though. all seals are new and my fuel rail isn't bent. what else can I do? is it possible the spacers that the screws go through expanded?
  • For sale 2g 2G DSM ECU
    Came off a 1997 GST M/T. Stock ECU
    • Stizzydrew
  • For sale 1g 90-91 Talon pass taillight.
    Pass taillight for 90-91 Talon. Good condition. No breaks or cracks. Will buff up nice...
  • For sale 2g 2G Manual Window Assemblies, Door Panels, & Hardware
    2G Manual Window Assemblies, Door Panels, & Hardware $250 + shipping and paypal feesYou must...
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
