Talonman86096
- 206
- 4
- Feb 22, 2006
Elizabethtown,
Pennsylvania
Ok so I thought I had my problem solved but I guess not. I threw a P0300 code the other week and long story short I got link working and was able to clear the code and set the DTC's to not check for cylinder misfires as well as Invert the CAS. Car was running great the last two days. So today I am driving and the CEL comes on again and it starts the same symptoms. I limp home and plug in link and am getting the same code and the cylinder misfires is checked again and the invert CAS is back to being not inverted. I didnt disconect the battery or anthing like that so I dont know why it reset or didnt save from the other day? Any ideas??
Also I did a log with the key just on the on position car was not running. I dont now how to post a log on here...I am using Link 2.5. At the bottom of the screen it said the A/F ratio was 18:1 which is way to lean from everything I read. The timing was 5.2, front o2 sensor was .4v. Im still learing link and I dont know if I need to do a log with the engine running or if the key in the on postion will give any kind of insight. I have 550cc injectors with the dead time set at 180 and global at 19. I dont have a wide band yet because I am just a little tight on cash at the moment so I am trying to get it so I dont worry about running lean. So what do I need to do basically
. I'm sorry for sounding like a complete newb here but I really am when it comes to tunning.
I am running a Big 16g. My boost gauge at wot will go to about 15psi, however the gauge sits a little more then one dash below zero when the car is off so I dont know how accurate the 15psi is.
. I'm sorry for sounding like a complete newb here but I really am when it comes to tunning. I am running a Big 16g. My boost gauge at wot will go to about 15psi, however the gauge sits a little more then one dash below zero when the car is off so I dont know how accurate the 15psi is.
Loose battery cables? Double check you battery connections??
