A/F and Volt gauge question
Phaze1ne
36
Jun 25, 2004
???, Minnesota
I just bought a Talon that came with an A/F and volt gauge. The previous owner had these gauges already tapped into the engine so they were once working, but had cut the wires from the back of the gauges for some reason. Now I need to know where the A/F plugs into, and where the voltmeter plugs into so I can find the wires, and bring them back to the gauges.
It depends where you want to tap into for the A/F gauge, I'm guessing its a narrow band A/F gauge. You can tap into the the signal from the O2 sensor inside the engine bay or you cna do it by the Ecu. Make sure you solder it in properly and use shrink wrap.
