A couple leaks under motor
sccrbrandon4788
179
3
Sep 14, 2008
Lexington, Kentucky
I was under the car today adjusting my exhaust system and noticed a leak at the clutch slave cylinder piston, but on the transmission side, not the cylinder itself. Another concern was above my oil filter there is oil on the block. It could be from where my PCV hose wasn't tightened down well and got oil on the valve cover, but I can't see where its coming from and it looks like its just the bottom end of the motor.
First one is the transmission area:
These are from the back of the motor, looking up:
Check your timing tensioner bolts for second one I ran into same problem awhile back and rtv'd them and went away.
