A/C Turns On/Off By Itself
Boosted98gsx
2,099
22
Oct 31, 2002
Houston, Texas
Driving around town or on the highway with my A/C on, it will blow cold for about a minute then blow warm. Knob is all the way in the blue, recirc/ambient doesn't matter, and the A/C light stays lit the entire time.
I had my A/C system checked out at satan a year ago, i have no freon leaks.
A year ago, a day ago, doesn't matter. You can develop a problem at any time. Put some gauges on it and give us a reading. If your condenser fan has quit, you could be developing high head pressure which would do that. Get some actual readings. That way we can have something to go on. See if the lo pressure line is cold, wet and sweaty. You could have a bad cycling switch or anything. See with a test light while it's kicking in and out if the voltage to the compressor is also kicking in and out. If it is, then just follow it back to the source. A good schematic is vital at this point. Get one.
From past personal experience, the thermo-switch inside the compressor is probably shorted out and allowing the compressor to overheat and shut off. The only way I know of to fix that is to replace the compressor. Maybe an AC shop can rebuild it but I dont know. If it blows cold at all that means that there is enough refrigerant to get the pressure switches to activate the compressor and make cold air but the compressor may be overheating.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
