bcjjones
- 509
- 6
- Nov 3, 2011
Austin,
Texas
Re installing my a/c. One of the lines on the back of the compressor was already bolted on, and the other one was just dangling there. I went to bolt up the other hose, but couldnt get it to fit in the hole. So I gave up on it. Then after putting a new clutch on, and coming across all the mistakes made by the previous owner(s). I had the idea to switch the two hoses on the back for the compressor and see if that worked, and of course it did. Before I go filling it up with some freeon(already converted to 134) and hopin the a/c compressor is still good, I just want to make sure I have these run correctly.
So from looking at the back of the compressor, the a/c line coming from the passenger side goes to the top or bottom hole on the compressor? Same goes for the hose coming from the drivers side, does it go to the top or bottom hole on the compressor?
I wont tell you which way mine is set up until I get an answer! Just dont want any confusion
