Spyder 99 Eclipse Spyder convertible top seals
All those parts are long discontinued unfortunately. See if you can find any from a 3G Spyder as the top is nearly identical. I got some seals from one that I have yet to try out, but it's an option.
Thanks but I did find some used on eBay for less than $100
Now I’m having issues with my car falling on its face under hard acceleration for just a second then it jumps right back and mind you this thing has some power so when it does it it nearly gives whiplash
Update cars running strong but blowing tons of white smoke doesn’t smell like coolant, oil, or fuel just like normal exhaust but I did discover that I need a new turbo mine’s leaking exhaust and oil and has shaft play
I have 2 t25’s that have shaft play and a tdo5 that doesn’t have much and I have the stuff to change it over but due to it also been sitting out for a long time it would probably go out in a week and although I’ve been a mechanic most of my life professionally for about 7years then went military until I got disabled I don’t want to have to change it again if it goes out on first drive. Also I’m broke but my Camaro has a bad transmission and my Silverado has to be tuned since new cam so this is only thing I have to drive. Can someone tell me the cheapest route to go as far as just being able to keep it drivable without spending $500 on another turbo. Please
