98 eclipse
Status
Not open for further replies.
Mit3kVr4
Aug 3, 2006
Perry, Michigan
Hey everyone im trying to help my friend decide to either turbo his 98 GS or get a GST engine and do a swap. I think the swap is the best bet but if he kept the GS engine what kind of boost could he run with a evo16g with sup mods. Also what is the engine 420a or 4g63?? I own a 3000gt VR4 so i dont know too much about eclipses.....Just want to see another mitsu go fast!!!!! I would appreciate the help.
nick
Between the two options, turboing the current engine would be cheaper and easier than swapping in an already turboed one. The engine he currently has is a 420a. The 420a can support in the area of 6 psi safely on stock internals.
So he couldnt run a evo 16g unless he had a wastegate that was at 6psi.......also would a 4g63 drop into a 98?
ok i answered the second part of my question. Does jdm sell 420a or can you only find them in the US. Sorry for the questions......i have a feeling im going to be on this site alot.
4g63 will not swap into a 2gnt bay. A simple search would have told you that right off the bat. Secondly, stock 420a is good for between 8 and 10 psi. Depending on the current condition of the motor. A quick compression test can give you some insight. An easy solution would be to grab a wastegate actuator from a 14b and attatch it to your 16g(if you were to run this turbo). They are originally set for 8-9 psi.
Too many questions that have been answered before... search before posting next time.
Status
