98 eclipse spyder turn signal problems
Match3tt
Sep 30, 2012
Clio, Michigan
So today I took off the center ac unit (the one with the hazard and defroster switch) to paint it. I also took of the panel for cruise control and fog lights. I unplugged all the connectors on the back of the panels. Today i was drving (I had them off still as they were drying) and i noticed that my turn signals didnt work. When i got home i plugged my hazards in to see if they were working. They were, yet still no blinkers on all four corners. I have read about the turn signal switch going bad on these cars, yet i think it would be a big coincidence seeing as i had just unplugged my hazards and such.:banghead: If you have any ideas on what this could be i would appreciate it greatly. Thanks.
Thanks for the advice but i figured it out, when i put the center ac panel back in the defroster and top switch connections were loose. Im not sure how this affected it, but pushed them in all the way and now i have blinkers!
ok so im new and it wont let me make a new thread but im having a simular issue with my 95 gsx 5 speed. i picked up the car with no blinkers but hazzards work. i replace the turn signal arm, iv checked fuses, iv checked wiring, iv made sure all bulbs are working and nothing corroded anywhere, and cant find anything wrong. is there a seperate blinker relay on these or is it the same relay as hazards? if there is a seperate blinker relay, can some one tell me where it is? iv run into a wall and idk where else to look.
Hey, a similar thing happened to me (95 gsx). I was switching my 2ga headlights for a 2gb set, and somehow after the conversion i had no hazards or signal lights.
it turns out i had burned 2 fuses.
One of them is in the fuse box in the engine bay ( for hazard) and the other one in on drivers side fuse box, the fourth fuse from left to right, top roll.
you might want to check that.
ALSO: theres one relay for both, that is behind the radio.
