97 gst spyder turbo wont run right. Need advice
sascorp
Dec 7, 2006
Jamul, California
:dsm: I have a 97 gst spyder 2.0 dohc 4g63 head with a cyclone manifold.
Originally got the car with bent valves. I replaced the head with an older one with the manifold. I got the car started but i have to give it a shot of starter fluid first.
It Idles but feels like it is running on three cylinders. I also ran an obd on the car and came up with a Manifold differential pressure sensor circuit malfunction error.
I checked to see if there where any vacuum lines loose but nope !
I did notice a little difference from the original manifold( it has an egr valve) the cyclone manifold doesnt so the sensor is just hanging there. would this affect the way the car is running?
How about if the timing is off a tooth or two, would that affect the car dramatically to where t would feel like it was running on 3 cylinders and very rough?
When I push on the accelerator, it dies !
Please somebody help me !
i had a mdp sensor on a few months back..it didnt change the ride of the vehicle at all really..its just there to regulate the pressure in the intake manifold. timing could definitely cause the car to ride rough seeing as how your valves will be open at the wrong time. that would either crack (chip/damage) the piston, the valve itself, or cause lower compression seeing as how the intake or the exhaust valve may be open during the compression or power stroke. "when you push on the gas" how much?? wot or even the slightest amount?
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
