97 ECU in a 95?
EclipsingJAX
Jul 18, 2002
Tallahassee, Florida
Hey I found a person who is completely unaware of what eprom ecu's are and I wanted to know if I could just swap my ECU(1997 GS-T) with his ECU(1995 GS-T) with out any drivablity problems.
im pretty sure you can just stick an eprom ecu into ur 97 gst. how else are u suppose to run a dsmlink without one? so my guess is that its interchangeable.
Yes you can use it. I would make sure it is an eprom though, otherwise you'll be trading for nothing.
You will have to switch the spark plugs wires: 1 with 2 and 3 with 4.
-T
My question is will his 1995 be ok with with my 1997 ecu in it? Will I have to change the order of the sparkplug wires as well on his car?
i dont think its that simple .. slappin yer 97 ECU in his car. i think its a little more involded then that. off hand im pretty sure ya gota change the plug wires.. and swap the injector pins at the ECU plug. 95's also use a diff style CAS. id loook into it more if i was you.
Im in the same situation, I have a 95 and my ecu was stolen, I found a 97 one and I bought.
I already swapped the spark plug wires, 1-2 3-4 but the car don't start.
it bucks a little but don't start.
what else can I try?
