crippledgimp
- 0
- Mar 23, 2011
Chicago,
Illinois
Hi, I'm EXTREMELY new to working on cars, but I've done a lot of research (I learn best by just researching and trying) on swapping out an engine for a 2G Eclipse. I've read in a couple different threads and websites, that you can remove the engine without having to take out the transaxle.
This is the approach I took to swapping out my engine. I've removed all connections, hoses, etc. and I'm to the point of hoisting out my engine. I've unscrewed and removed the left roll mount for the engine, and also removed all the screws to the bell housing. The engine obviously pried apart from the bell housing, but now I'm having the difficulty of trying to get engine out (right now it's fully supported by the engine hoist). I've read that you can remove the engine without having to take off the crank pulley, but apparently it is easier to do it with it off. I haven't taken the crank pulley off yet, I figured I would ask before I start taking stuff apart.
So my question is does anyone have a recommendation/advice/tips on the easiest way to remove the engine at this point? The engine probably has about 1" of room to move left or right.
. but i def prefer that to a chain fall in the barn like i did the first 2 times
). If the torque converter is not on properly, you will ruin it.
