97 Automatic GSX wont go over 3K RPM
rgj710
Feb 28, 2011
New York, New York
Recently I was driving to work and stopped at a light after the light turned i noticed that the car would not drive upto or past 3000 rpm. The car is very lazy even if i floor it. The car isnt breaking up at all it just wont go. It is an automatic gsx. Any ideas?
start small and work your way up to bigger things.. start by doing a boost leak test (as everyone will tell you to do), changing out the spark plugs to ngks, check for any breaks in the spark plug wires..etc. My guess is a boost leak in your intercooler piping somewhere...
Sounds like the car may be in limp-mode. Theres obviously a problem. I would drive very safe until you get it fixed.
Check all the innercooler hoses and connections. You may have a boost leak, the same problem happen to me. Found the upper innercooler hose came loose.. gd luck!
I would look for boost leaks and couplers that have blown off. I would tighten all your clamps on the upper and lower intercooler piping.
