95 Talon TSi AWD CV Axles
rwood585
Jun 26, 2008
Farmington Hills, Michigan
Ok so this is the deal. From my searching I have found out some info on replacing the CV Axles and that all four are slightly different in their own way. I'm looking to replace all four on my CV Axles with brand new ones. I can't seem to find out exact part numbers or even a good place to purchase them from. If anyone could guide me in the right direction that would be great. Also remember I have a 95 TSi AWD...thanks
HAHAHA!!! Good luck w/ that. I ordered a set of front ones from a company for my 95 GSX. They came and were too big to fit in my transmission. They insist that those are the right ones because they take them out of the car, rebuild them, and then ship them out.
Long story short, I wound up buying one side as a 1st gen with a custom ABS ring, and the other was from the 2.4L model (I'm assuming they meant the spyder, not sure how that is different though). I also kept the original set that they said "should fit". If you can measure the diameter of the splines that go into your transmission, and the over all length of your axles, we can see if I have the ones you need.
Are you looking for OEM replacements, new bargain brands, or remanufactured? I've bought one from Rockauto.com for my A/T and was pleased with the quality. It really didn't look that different from the OE one I removed. Everything was clean and burr free.
Yeah, I'm just looking for anything "brand new." I don't need high HP ones just something to replace my old ones that are worn out and stuck in the old bearing :)
A lot of this is very helpful, thanks. Seems like it's a hit or miss trying to buy these though haha. I don't have them out of the car yet either so it makes it that much harder.
GET THEM OUT! And measure them 4 times. Then ask to have the new ones measured and compare. Maybe I'm a unique case that had issues buying these, but I can't imagine that.
