95 RS Problem
2GJeremy
150
Nov 13, 2011
Hilliard, Ohio
Here is the problem, i hit my gas and the car will stutter realllllyy bad. If i don't smash the gas and try to drive normally it feels like something is dragging the car, 80 percent or more of the speed taken away. But, if i do smash the gas it will go with no stutter, but still will not even see half the speed it use to before this problem arose. To give you an idea of what it feels like, it seems as if the spark plugs are not well.... sparking. Like they are all faulty or have oil leaking to them. I found oil in the spark plugs awhile ago, replaced the spark plugs, valve cover gasket and cleaned the holes and have gotten no results, still doing the same thing.
Things I have done to attempt to resolve this issue;
1. I have put fuel injector through the tank and ran the car through 2 full tanks.
2. I changed the spark plugs & the wires, cleaned out the spark plug holes.
3. Changed the valve cover gasket and cleaned my entire valve cover area.
4. Tried to double on the fuel injector cleaner.
Things i may have done to caused this issue;
1. Ran the car through winter without a gas cap. I got one now, and it's actually been hot outside on some days. But still no result.
2. I have heard around from a couple of my buddies they know that my EGR Valve is bad, I have yet to change it due to this issue for the reason that I took it to the mechanic shop down the street, they said a EGR Valve would not cause this issue.
Somebody help, I've got a competition coming up and I have to take the car to Florida in a week or so.
Additional Details;
114,000 miles on the engine, gear syncros under a grand, and the clutch is kind of worn but not that bad at all. Full Synthetic Oil Change with frequent oil in the engine, and all other liquids are kept up to date.
Thanks.
P.S. I ONLY RAN THE CAR WITHOUT A GAS CAP FOR ABOUT 2 WEEKS OR SO. STILL BAD I KNOW, BUT I DIDN'T MEAN ALL THE WAY THROUGH WINTER. For i live in Ohio, and that would be a long time. -_-
First replace your egr valve because it can cause some issues sounding like that. Heres a test if you have a vaccum pump then put vacum to the valve at idle the car should stall when you do this, if it doesnt replace you egr. If that doesnt work i would suggest a compression test. Are their any fluids mixing oil/water? Are their any cels on?
No CEL's on and no fluids mixing. Im honestly completely stumped. But hey, i knew what i was getting into when i was buying a DSM. LOL.
EGR wont cause any problems like this, and if it is really bad that you will have a CEL. Running the gas cap might of been the problem, if you did this during the winter, its possible you somehow got enough moisture in there, aka trying to say you may have water in the tank, or bad gas, not likely but possible. Try checking your catalytic converter after running for a bit to see if its glowing red, almost sounds like a plugged cat to me.
DOes it sound like its kinda choking when you put your foot in it? Sounds like it could bet the cat to me as well. My 93 Explorer had the same problem, gutted the cat and she ran like a champ! Loud as hell too LOL
I curently have this problem has been going on for about 2 weeks i know my problem though. Its my cam shaft sensor....does the car start right away or does it crank for a while? Check your camshaft sensor. It helped me :)
Yea egr wont cause that serious of a problem, definetly check the cam sensor. Its odd you have no codes popping up. Make sure one or more of the brakes are not locked up.
