95% inj duty cyle at idle??
lauj2gdsm
326
Jan 16, 2005
stockton, California
Ok my car been running really crappy lately at idle and also throwing missfire code.. will today i was missing with my avc-r and switch over to injector duty cycle monitor.. at idle it was 95% while dirving my duty cycle was a 95% dropping down to 80% as i go on the throttle.. Dude is that correct at 95%???? does not sound right at all any wise man??
With 650's @ 95% inj. duty cycle at idle Its hard to believe the car would even run... Somthing has to be off. No wideband yet?
Yea it starts really hard.. dies a few time at start up.. sometime it gets flooded too i think because if it dies a few time ill have to wait several minutes before i can start it again.. then when it holds idle it hold idle at 100 to 450 then ( really crappy ) after a few minutes it will go to 750 and hold fine but i can feel the studdering. and yes i got a wide band but gave up on putting it on at the time due to this issue. you guys think it can be the mas??? I think i just got to get my lazy ass to do a boost leak test.
Something is definitely wrong, that's like your injectors firing for full throttle, at idle LOL.
That's just reading backwards. It's really 5% at idle, and increases to 20% as throttle is applied.
I'm not familiar with your tuning software(what is it btw? It says ECU+piggyback), but on another turbo project I built, I had the same backwards IDC problem. Wiring was correct, but I had incorrectly choosen the method of reading the IDC. I switched back, and it read fine. This was with Innovate software.
