95 gst builds boost when reving and has zero power
theSicKness
776
4
Dec 26, 2004
Belpre, Ohio
As the title says im trying to help a kid with his car and can't not figure this one out.
Symptoms
When reving car builds 10-11 PSI (almost like anti lag if you use dsm link)
Car has no power when trying to move it
when car is being moved its constantly spooling
Wont rev past 5k
when car is shut off you can hear air/pressure being released.
manifold glows
blows black smoke under boost, obviously running rich
Things checked
Timing is perfect
checked inter cooler pipes very small leaks if any
Compression is perfect
tried unplugging various sensors
Any help would be appriciated
Mods to the car: 14b and exhaust and K&N everything else is stock,
Well with 95,96 the computer sets the timing off the crank sensor and cam sensor... we may have figured it out.. being the wrong ring installed for the crank sensor to read off of..
Do you have a logger? What does the TPS percentage say? Mines at 100% and I am having similar problems. It very well could be wiring problems I am experiencing, which could be your culprit as well. Or it could be a BOOST LEAK. Do you have a video?
I was thinking it was your car missed the first part their
But
It Still sounds like the timing is off to me...
The Battery in this car is also extremely weak, after about two attempts to start, the battery is dies. We have been using a batt. charge when we start it. Could a bad battery be any affect on this? He told us that he used a crank plate from a 94 on this as well.
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
