95 fuel
95 gs
Nov 12, 2004
spring hill, Florida
if I put a turbo on my 95 420a will I have to upgrade the fuel and if so can I use gst injection
You need a Fuel pump as well as a FPR over 5 psi (I will prefer to do it to be in a safe margen!) you can use stock injectors up to 6 psi but the Duty cycle might be almos 90% = not good!
Yes you can use the gst injectors (440cc) BUT You are going to need to use a couple of resistor to use it. Because, It is low reistance and ours are high resistance.
so look trough the forum about it or search in www.2gnt.com
If I were u just look for another injector you don't want to mess with wires!
You may ended up having to use an S-afc! or something to tune the fuel!
Later,
