95 CAS in 97
97fwdtsitalon
83
Jul 17, 2004
greenspring, West Virginia
i just bought a 95 motor for my talon and it has a different CAS. i was wondering if anyone knew how to wire it up. i searched and came up with nothing.
What happened to the CAS off the stocl motor. I'd put that on the 95 motor.
will i have to modify the 95's intake cam to put the 97 CAS on? the 95 CAS is by the cam gear and the 97 is on the opposite side.
Do you have the harness for the 95 CAS? If you're swapping an entire 95 motor into your 97 and you don't want to deal with the wiring, just swap the 97 intake cam into the 95 head and use the 97 CAS on the head (it'll bolt up).
IMPORTANT *** remember to MARK the CAS cylinder (97) so you align it correctly when reinstalling.
thats probably what i will have to do if no one knows where i can find the wiring diagrams for the two years. i dont have accsess to the repair manual right now and i just about have the engine in my 97 now. thanks for the help.
