97 cam sensor in a 95
62-1gsx
175
Mar 31, 2003
des moines, Iowa
can anyone tell me how i would hook up a 97 cam shaft sensor in a 95(i got a 97 motor in my 95)? what wires on the crank shaft sensor to i tap into?
any help would be great,
thanks guys
alexg1323 said:
just ditch the 2g cam sensor and crank sensor and wire up a 1g CAS. there are already tons of diagrams out there on how to do that. It only takes 1/2 hour
I strongly suggest you don't. Ever hear of random misfire from the guys that put 6 bolts in their 2gs?
well you can follow those wire diagrams to wire up that 97 CAS but it hasnt been done much so who knows if its fine like that, you need to swap the plugs, swap the injectors, or both. ALot of people like myself are fine with the 1g sensor
so what if i take the 97 cas off and then just replace it with the 1st gen, its that easy (other then makin sure the teeth go back on the right way on the sensor to the cam)
what is the easiest thing to do then, can i just take the cam gear off and put the 95 one one along with the sensor, or do i have to take apart the whole cam assembly. im trying to save work, i just got everything together i really aint tryin to take it all apart again.
