420A 95 420a ECU Pinout?
Carter_95RS
568
9
Sep 17, 2009
765, Indiana
I got my AEM UEGO wideband today and i'm preparing for the install. I've read the instructions and also the tech article as posted by gofer here http://www.dsmtuners.com/forums/articles-electrical-wiring/383190-1g-2g-aem-uego-wiring.html and then i have also found the pinout for a "2g" eclipse here http://www.dsmlink.com/images/forums/2GECUPinout.pdf
I believe that is for a Turbo ECU, so my question is will I tap into pin 76 (white, front 02 as shown on turbo ecu pin out) or is it different for the N/T ECU?
It sounds like that's the wire for the UEGO's simulated narrowband output. If so, you're looking for a white wire with a black stripe.
You should know that using this feature doesn't usually work well with our cars. You're better off installing a second bung for the wideband sensor.
So i should create a new 02 location and tap into the white wire with the black stripe?
and the wiring would go like this
RED wire to a 12v ignition power source
BLACK wire to a chassis ground
WHITE wire gets wired into ECU's white wire with black stripe
BLUE wire is unused, zip-tie it off out of the way
