420A 93 oct vs E85
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
So I've been running E85 on my daily but had to run 93 the other day cuz I almost ran out of gas but it seems like my car acted more responsive. Car is internally fully built. I have a Walbro 255 upgraded lines, and I also have a hahn port fueler running stock injectors and the high flow injectors Hahn supplied with the set up, my car is also running a aem fic 8. But its tuned on 93 not E85 yet. But can still runs amazing on E85 just I dont know seems like it got more ass behind it on 93. Any input ?
With e85, you can increase boost and timing. Ethanol on a port injection engine cools the air before it goes into the combustion chamber. It’s basically 106 octane fuel but like stated above, you need about 40% more ethanol than gasoline. You’ll also want to change the fuel filter to a SS element as it will deteriorate paper & fiberglass. Also upgrade to anodized fuel rail.
See that's all new to me. I was told just run larger lines and a bigger fuel pump?? I mean I been running e85 for about idk 5 months now never had a fuel leak or lean out... and I have a stock rail, fuel filter, etc. What else do I need to run e85 correctly and get the power out of it ? Minus the tune I can get that covered
Many times on E85 you would want to run less timing, the actual big advantage to E85 is the cooling properties of it and the mass of the fuel itself that you can burn.
What? This is the first time I’ve ever heard that before..
Very true though. So this is the key aspect we need to understand here. And the part that is often overlooked is that the burn speed, the combustion speed, on ethanol blended fuels is actually faster than what we end up with on gasoline. So if we understand that, what this straight away should suggest is all things being equal as we move from gasoline to an ethanol blended fuel, we may need to retard the ignition timing, start the ignition event later. Of course the other aspect with ethanol is that it has some properties that make the engine much less prone to suffering from knock or detonation. And obviously this is one of the reasons that we as performance engine tuners are drawn to E85.
Burn speed of E85 changes dramatically with mixture, it burns much faster (needs less advance) at high power rich mixtures. At more typical mixtures it burns about the same as gasoline or slightly quicker.
Because of its high octane it will allow you to run more advance, that does not necessarily mean the increased advance gives more power. One of the most common mistakes tuners make is over advancing timing looking for that last little bit of power. That removes all your safety cushion for when things go bad (pulling a hill fully loaded on a hot day etc.) and boom there goes a head gasket or a piston.
If you make small incremental changes in timing 2 degrees will usually show a change if there is one to be had. And you have some means of comparing relative performance (dyno, time 0-60, max speed pulling a hill, Gtech or something similar) the engine will tell you what timing it wants. You are looking for what is called MBT (minimum best torque timing). It is the lowest ignition advance that gives you 99% of your max torque - best power. That is the safest tune and you give up only 1% of your engines max power 2-4 hp on most engines.
So going off the assumption that you tuned your car this way, may I as, what your peak timing is?
