92fasttalon
- 1
- Aug 17, 2005
laurys station,
Pennsylvania
I am going on my third ac/alt belt in two months. Also this is my 2nd alt in 3 months. This last alt has lasted fine but I keep burning up belts. The car always starts by screaching the belt and you can smell it. It will run at about 12.1-12.5 on the volts while it is screeching. When screeching goes away volts jump up to 13.7-14.2 depending on how much throttle. Weird part is this is not just at startup. If I am stopped at a light and I pull out the screeching comes back sometimes, when I turn my wheel it comes back sometimes. The belt has always broken while it was screeching.
When I bought the car (92 talon 4g63 turbo) it had a newer underdive pulley on it. Could this be my problem? I thought that a smaller pulley would turn the belt faster and might go through belts faster. Would a stock pulley solve the problem (suggested by a friend)
Any help would be great, and Thanks in advance.
