91 tsi rough idle
jcorn517
Feb 22, 2013
Rockford, Illinois
Hey guys I'm totally stumped I got a 91 tsi awd completely stock it has a horribly rough idle all the time I've replaced plugs wires checked for boost leaks and can't find anything wrong except for the blow off valve (1g) when I take the recirc tube off there is a solid stream of air coming out...could that be my problem? Need a new bov? Any ideas would help please thanks
That may be your culprit, there shouldn't be air coming out of your BOV at idle. I'd check that there are no more leaks in the intake system, all your vacuum hoses are in good condition, and you don't have any major wires unplugged (like to the CD deck) as well. Good luck.
Shouldn't that be under vacuum at idle? That'd be sucking in un-metered air? Running lean at idle will cause it to idle rough.
What happens when you plug the BOV opening with your hand, does the idle smooth out?
It doesnt matter if the bov even works if the recirc tube is in place. It will not affect idle. Yes a bov should blow air at idle if you remove the recirc tube. Thats how a bov works, it opens under vacuum signal from the rubber line. Did you check for leaks? What is the current rpm at idle? Did you check base ignition timing? Did you check mechanical timing? Does the car have balance shafts?
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
