91 talon wont start
turbotalon31
386
3
Jan 9, 2010
reading, Pennsylvania
ok guys i have a 91 talon tsi car ran yesterday and today wont run. have spark, have fuel , and good compression checked all my electrical plugs and still nothing car just cranks. anyone have any ideas? fuses relays or what not ?
What was the last thing you done to the car, if you have those three things the car should run.
how did you check those 3 things, did you pull a plug to smell for fuel? did you did you use a spark tester? cause apparintly your missing one of those three. only time i had this happen is when my cts came unplugged and it seemed like i had those 2 but i didnt.
also is the car just cranking like it doesnt want to start or is it trying to start
found out i dont have spark and when i do it is very weak
im running a coil on plug setup. and the battery has 12v
on the plug to the coil do you have a refernce voltage and 12v supply to the coil it coul be a bad refernce wire to the coils or bad ground. need more info which cyl are missing spark. i would check your wiring. and check the coils
tuned out i was dumping to much fuel and it fouled out my plugs
