90 to 93 brake upgrade
will the caliper bracket for the 93-94 be the same for the 90, cause i have the pads, shims, and if i can use the same bracket i have those too.....the only thing i lack is having the 2 piston caliper and rotors
will the caliper bracket for the 93-94 be the same for the 90, cause i have the pads, shims, and if i can use the same bracket i have those too. the only thing i lack is having the 2 piston caliper and rotors
No the brackets, pads, shims and rotors are all different for the dual piston calipers.
Sweet got some new tires already thats why I ask might do this in the near future then to slow down the ride with the new turbo.
Just a quick note: 1g "big brakes" have screw in brake lines and 2g "big brakes" have banjo bolts. Try to get a set that matches your car so you do not have to get special brake lines. If you mismatch them, I believe RRE sells hybrid lines.
Oh thanks for the heads up man. Soon as I finish all the parts I got chillin in my basement I will probably start collecting parts for my handling. But again thanks for the heads up.
