90 and 91-? tranny differences x230847203984
kelvinb
726
3
May 7, 2004
Lincoln, Nebraska
I took a look at my clutch after 1k miles and all looked good. Hooked everything back up again and I see a leak :notgood: Turns out the driverside cv shaft seal has a hole in it. I call the local Mitsu dealer here and find out that seal is $430 ROFL ROFL I told him I had the previous tranny still there and he said it should fit. I go home and pop the old one out and tearing it all up in the process. I 'try' and put the 'new' one in from the old tranny and the diameter is to big :mad:
So
Tranny seal is different from 90-91-?
The 91-? is a black rubber piece
The 90 is a copperish colored lip with black rubber on the inside
So
$430? It's about 6 bucks at autozone.
On my '92 tranny, the seal had the copperish metal lip as well. I got this one from the a dealer for under $10, if I remember correctly. I had also purchased one from Napa for cheaper a while back. Be careful at Autozone, they had it listed as the same as the passenger side. They are different.
Mike
