90-91 Talon TSI Help
mud chicken
Nov 17, 2006
Schuylkill Haven, Pennsylvania
Im looking at 2 Talon TSI AWD 5spds first is an 90 and the second is a 91. What do I need to look for when I check these out? Both have some mods done and redone 6 bolt engines. Im not sure of problem areas to check out so any advice would be great. Thanks in advance.
ok, after some more searching I found this http://www.dsmtuners.com/forums/fre...estions/238710-dsm-used-car-buyers-guide.html
Does anyone have any other things? Again thanks in advance.
Just look for hack job half assed mods, toggle switches to nowhere(my car wouldn't run for the loggest time because previous owner rigged up a kill switch to the ignition coil and fuel pump and a wire was grounding where the insulation wore through), ductape anywhere, check the oil, ask when the timing belt was replaced last, make sure it doesnt have a knock off chinese turbo on it. Make sure the car shifts smooth, not all knotchy and grindy. Check the tires for even wear. Basically just see if the car was taken care of properly and wasn't abused.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
