86mm wiseco pistons in a 7 bolt?
3SGTE pistons have a compression height of 35mm and use a 22mm pin, same as a 7 bolt 2.0L 4G63.
I'm not absolutely sure, but I imagine that they could be made to work with some minor machining as long as the valve reliefs are adequately cut and the small end of the rod fits between the pin bosses.
The compression ratio will obviously be slightly higher than advertised for the 3SGTE since the Toyota head has a 49cc combustion chamber and a DSM head has a 47cc chamber.
Got any pictures or measurements you could post from them?
