Smokin80
- 239
- 117
- May 2, 2006
Hey guys,
did the first runs on the 3065 at the 1/8 mile this weekend. Had some growing pains but in the end i ran a best time of 7.732 and a best mph of 96.xx at 23psi. Was running 11.5ish afrs and fairly conservative timing....17-18 degrees above 7000rpm and 9-13 or so in peak torque area. Was running pretty consistant 1.7 60's but im sure it has more in it as it was spinning all 4 tires REAL hard no matter what i did.
Was having maf problems up in the 29psi range so i didnt get any clean runs at high boost.
here are the vids
Look closely in this one after the 1-2 shift and you can see the harmonic damper come off the car
thatll happen hitting the limiter in first at 9250rpm. WOOOPS new one is on the way
here are the vids
