6bolt head into a 7bolt engine!!!
dsmimports
Sep 9, 2005
PROVIDENCE, Rhode Island
:dsm:HI , I have a 7bolt engine and i was thinking I could putting the 6bolt head into my engine but I don't know what to do? I know that there something I have to do with the cam angle or the wires. what wire go to what? I also hear that you can shave a little bit of where the camshafts go to. need some help!!!!:dsm:
What year 7 bolt? Is your CAS on the timing belt side or inback of the intake cam? If you have the 97+ style CAS, it bolts up to the 1g head. If you have a 95 style crank angle sensor, then you will be doing some rewiring. Besides figuring all that out (use the search feature), just get a 1g waterpipe and thermostat housing, 1g intake mani or aftermarket :sneaky:, and DSMlink to make things easier for you. That should be it, everything else should be a bolt on affair... oops, 1g throttle body reusing your IAC from the 2g and TPS, 1g lower radiator hose, or just buy a nice set of SS steel from ebay or staycool, or something like that. It basically allow you to cut to length the radiator hose you want.
Anyone else, if i'm missing anything please put in your nickels worth!
Thanks,
KJ
