660's + 15psi + 60-1= 0.01v?? WTF
jazzyjay
216
Mar 27, 2003
As the post says I have 660 denso injectors a 60-1 turbo at 15 psi and I am running very lean with minimal Knock I install a new sensor(knock). So am I really lean tested Knock sensor and it works. I have knock at lower rpm's I try Using my ZT-2 but it screws up TPS signal (reads 100% all the time) :confused: another problem to figure out. HELP!
Well honestly if you barely have any knock why worry about it. If you tested the knock sensor and it in fact works, then you have no problem. Check if your o2 sensor is plugged in, sounds dumb, but thats what it'll read if its unplugged :p
