420A 60mm Modern Performance Throttle body
Eclipselover91
6
Jun 18, 2023
Gatesville, Texas
Will a 60mm modern performance throttle body work with my stock intake manifold it lines up fine just making sure before I waste time just got through building the motor and putting it in now
Yes but I also have a throttle body spacer that's what I meant to ask about do I need to have it machined to the correct bore cuz it's a smaller bore but yes it's on a 95 420a no turbo yet
Firstly, yes that throttle body will work. I highly recommend boring the plenum to 58mm for maximum airflow. But you can technically bolt on the throttle body and be good to go. I recommend 58mm because boring it to 60mm is too much and will leave a hole on the front of the plenum.
Secondly, get rid of the throttle body spacer. It's doing no good for you.
