6-Bolt Timing Tensioners, and another discontinued part.
DSSA
Supporting Vendor
741
731
Jul 26, 2002
Hatfield, Pennsylvania
A couple of quick things.
1) We obtained a handful of 6-Bolt timing tensioners from overseas. *******PLEASE READ THE FOLLOWING CAREFULLY BEFORE ORDERING********: We sold out of the last batch in about 24 hours--leaving us with no inventory to sell timing belt kits. We are only selling these via our "Build Your Own" timing belt kits ( https://jnztuning.com/product/timing-belt-kit-dsm-gvr4-6-bolt-build-your-own/ ). Minimum of a "kit" would be a timing belt, idler pulley & tensioner pulley. Orders for less than that will be either cancelled, or put on back order status until Mitsu brings more tensioners into the U.S..
2) MD130457 (1G Turbo Upper Thermostat Housings https://jnztuning.com/product/oem-upper-thermostat-housing-1g/ ) are now discontinued by Mitsubishi. We have one remaining at the link listed.
Thank you!
Sincerely,
The Grim Reaper of Mitsu Parts. :-(
Have the upper thermostat housings been discontinued before? Seems like they were hard to get 10 years ago.
********************Thermostat housing has been sold and is no longer available**************************
Somebody out there is hoarding parts and should probably sell them.
On the subject of timing parts, it seems the following are in low supply worldwide and might be on their last stock:
MD191807 - 7-bolt middle timing cover - "out of production" on Amayama
MD332865 - 7-bolt lower timing cover - "out of production" on Amayama
MD198031 - 7-bolt upper timing cover - "permanently out of stock" on Amayama
