6 bolt swapped
torque77
31
Jul 6, 2005
kingman, Arizona
i just did a search on this because i havent been able to get my car to run right ever since i got it back from the shop and found out a few things that i need a little explaining after i searched. i believe the shop that did my6 bolt swap to my 2g head (99 gsx) put a 90 cas in the car. now is this right or do you need a 92-94 cas as i read while searching around??? the car is misfiring like crazy and the timing is way off. if that is true, how do i fix this problem. i can tune with greddy emanage ultimate and log everything so i know what is going on. that is how i know the timing is way off. thanks for the help.
http://www.dsmtuners.com/forums/showthread.php?t=186667&highlight=random+misfire
http://www.dsmtuners.com/forums/showthread.php?t=105641&highlight=random+misfire
http://www.dsmtuners.com/forums/showthread.php?t=194074&highlight=random+misfire
Some of that information should help if not look at RRE's webpage under the tech info and check how to fix it. Also magnus used to have a good walkthrough on how to fix it but I've lost the link.
Goodluck!
I had the same problem as you but I did the pot mod to fix it.
-Thanks
John
