2G 6 bolt swap into a 2g multiple cyl misfire code
2g's only have one motor mount. you are supposed to use a 2g motor mount cut around the 1g water pump to fit correctly. 1g tensioner arm must be used. Other than that, it bolts right up. Make sure you install a 2g starter mounting bracket ( a thin sheet metal plate between the tranny and engine) before you install the clutch and flywheel. The cas thing is tricky, I am having a hard time getting the timing straight on my car. I have a wideband and keydiver right now. I would reccomend a logger also.
THat is the help i need. THANK YOU SO MUCH FOR THE INFO. :thumb: This whole time i needed to know that kind of stuff. If i was there with u i would probably give u a kiss. But i'm not ### so i'm not going to. ;) Anyways all i have to say is finally i am getting the info i need. I heard that the CAS would be the only thing that will be of complications. If i find out anything to get around it i will let u know and maybe it will get u running up to speed. Again Thanks to all who actually told me things i should do.
