6 bolt swap CAS question
alkadaypx182
55
Jul 11, 2004
Wood Dale, Illinois
I'm trying to finish up a 6 bolt swap and I have a question regarding the wiring of the cam angle and crank angle sensors. For the red and black wires coming out of the crank angle harness, are they supposed to be connected to anything? the cam angle harness has 3 wires and all 3 are connected to the actual sensor. As far as the crank angle sensor harness though...it has 3 wires and only 1 actually goes to the cam angle sensor, what do I do with the other two?(red and black wires) Thanks a lot for your answers.
I obeyed that wiring diagram and she started right up! Hell yes, all that's left is to work out the little things.....I may have a boost leak here and there and then lastly....I need to tune it. Thanks!
Did you mess with the ECU wiring, or move your spark plug wires around?
No messing with the ECU wiring. If I read correctly you only need to mess with some ecu wiring on 95-96 models to get it to work right. Also I did not need to swap my wires they stayed "stock" 4-1-2-3. Any other questions let me know.:dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
