6 bolt in a 98, swap wires?
Lil' Shaun
210
Nov 30, 2003
dayton, Ohio
I recently finished my 6 bolt swap into my 98. It has about 600 miles now. it seems to have a miss at little to no load. was i suppose to swap some injector or coil wires?
everything on the engine is brand new except the mas air sensor, cam sensor and coolant sensors.
i am not running a map sensor, emission system, crank sensor, boost silenoid or fuel pressure silenoid.
i am also getting a code for a random multipule misfire. and sometimes it feels like the ecu shuts off an injector and the wide band goes to 18-20. if i hit the clutch till it drops to idle its fine when i let off the clutch. i did a search for that problem and they all say a new crank sensor fixes it but im not running a crank sensor.
I have 1200 miles on my engine now and its still shutting of an injector if I hold the rpm's at or above 3,000. When I have it floored and it does the wide band goes form 10-11.9 to 19-20 and letting the engine drop back to idle fixes it.
Does anybody hav any ideas?
Wow! 128 views and not 1 comment.
