6-bolt cam angle rewire neccessary with DSMlink?
BOOSTJUNKIEGSX
113
Jan 12, 2006
HILLSBOROUGH, New Jersey
Short and sweet...Did a 6-bolt swap in my 2g and used the RRE cas plug and play harness.. I have DSM link and want to know if i will still have to swap out injector pins on the ECU or will dsmlink be able to take care of it?
Will be firing my car for the first time tomm and would like to know if this will give me problems because i didnt do anything but plug the harness in. Thanks-
Green: Pin 1 is now 14
Green w/ yellow stripe: Pin 2, is now Pin 1
Green w/ red stripe: Pin 15, is now Pin 2
Yellow w/ black stripe: Pin 14 is now Pin 15
Is this correct?
*Do i even have to swap pins in the ecu or just change the spark plug wires on coil - 1 with 2 and 3 with 4.*
95 gsx
Is this correct?
95 gsx
You have to swap wires somewhere, either at the ECU, at the coil, or the plug wires.
Is this correct?
95 gsx
Yeah exactly. You can just swap the plug wires around. I would prefer to do that rather then mess around with the ecu pins. But either way, it has to be done.
