Korndogg
- 471
- 0
- Jun 21, 2003
randolph,
Vermont
hey all
i'd really appreciate help with this one
'96 talon TSI wouldn't start today. it was between -5 and -10 degrees.
the car just cranks over, and every once in a while it will kick up a bit. i saw the tach get to a bit above 500rpm once, but it was VERY brief. the car doesn't run at all then die.. it just kicks a little bit while trying to crank it.
at first i thought it might be the battery, so i took it to autozone and they charged and tested it and said it was fine. it's an everstart that's rated at 875CCA - 1000CA.
anyway, i ended up jumping my car to another that was running while i cranked it and it acts the same, so i know i'm getting good power.
yesterday i put a full tank of 93 octane in and then drove 75 miles on the interstate. i put some dry gas / gas antifreeze stuff in today when i couldn't start my car.
the car coughs almost black smoke while you crank it - mostly when it "kicks". (no cat on exhaust)
if i crank the car for long enough.. 7-10 seconds maybe.. i can hear a weird.... clunking? ticking? strange noise anyway. it soudns almost like it's coming from under the floor of the rear passenger seat.. like where a pass would put their feet on the rear/pass side of car. i don't know if maybe that's the sound of my fuel pump doing something? maybe my line is frozen up? but then would the car still belch black smoke?
anyway.. i would really appreciate help with this one.
let me know if you need info
thanks a lot guys
edit: i was trying to get the car started for 3 hours today so i could go home... to give you an idea how much time i've spent cranking on it.
edit2:
oh, and i've had this similar problem 2 other times this season.. the coldest days really -below -10. it wouldn't start with my remote starter, so i had to go out and give it 2-3 long cranks before it would start. and it was then too pushing some real dark smoke while cranking and then also for a short while after it started.
thanks a lot guys
edit2:
