56Trim Garret install help
SiNiST3R
347
May 10, 2004
NorCal, California
Okay, after searching through these forums and reading allot there seems to be allot of mix info. What I’ am trying to do is plug the Coolant lines or Loop them. What I need to know is should I plug them if so what size bolt do I need? Or do I loop them? I have a 2Gen GST with a 7bolt. Let me know the real answer thanks guys.
Zane
It really doesn't matter...what does matter is making sure your coolant lines are not leaking or speuwing all over. Just make use of whatever odd and end parts you have laying around. Good luck.
