560 injector pintle help
AllanL
274
25
Apr 24, 2008
LV, Nevada
got a set off the mail.
but one's got a cracked pintle cap. :ohdamn:
can i use the pintle cap from a 450 injector?
thanks
I never had a problem running with the cracked pintles, but i saw a thread on this earlier, im not sure if the pinltes will even come off.
Yes I posted in that thread too but the guy was installing 450 and asked same ? just other way around but never was said if they could be swapped. I'm pretty sure the nozzle is the same size just the spray outlet is larger so I would say they would fit but I have never tried to take one off so I am not sure if you can get them off and on without breaking them. If so then you just have to try it.
