50 shot or 100 shot
badas93tsi
495
Oct 17, 2002
Augusta, West Virginia
I searched around and couldnt find anybody with similar mods using nitrous. Starting from the top, HKS 272's, slight ported head, Eagle rods, Venolia "race" pistons, 770cc injectors, s-afc, mbc, fmic, and an ETE32(be nice I know its junk). What would be the best jets for my setup. The car has dynoed 309 to the wheels before the cams. Any help would be appreciated. :talon:
by the way im running 20psi
any suggestions on a brand, I was thinking NX????? Are they very involved to install, i.e fuel line splicing and stuff? just a ?
Nx is very good. Pretty simple and straight forward install. I've done two kits and both are easy. Wet shots pack a lot of torque as well (at least for 4.6 motors).
You can run a 100 shot without a problem. If its set up right.
As for the jets the fuel jet will depend on what your base fuel pressure is.
You will be fine with a fogger nozzle. A direct port is alot harder to change out the jets when tuning unless you have a sheet metal intake with the n20 bung on top. Even then it will be harder.
not exactly sure how it works, how does it add the extra fuel?
Don't take this the wrong but if you really don't know that then you have no business using nitrous.
i did take it wrong, i assume everyone just wakes up knowing everything about nitrous huh, if i knew everything i wouldnt be here asking questions would i?
That would be very correct. That's what I thought the forums were for. This is the first time that I have ever used nitrous as well. I've went through about 2 bottles so far. Good luck! :)
thanks for the help guys, i guess not everyone here is an a$$
I got my kit, most of the hard stuff done, trying to figure out where to put the solenoids. Any ideas or pictures?
