100 shot of nitrous
JayB98GST
72
Aug 20, 2002
i was just wondering if the stock internals could handle a 100 shot of nitrous using a direct port setup?
Depends on how much boost your running with that..
If your running stock 14psi a 100hp shot will pump it up to 18-19 on the puny stock internal WG plus the nitrous. I would probally say it will blow up the motor, espically a 7 bolt with the weaker rods. Nitrous creates a whole lot of instant cylinder pressure which is why rods like to snap and boost pressure likes to go up.
Running a 35-50 shot single nossle wet (NX EFI kit) with 16-17psi of boost would be a lot more effective, and cheaper too.
yeah, right now i run 15 psi on the stock turbo... so you say a 100 shot is probably too much? then would a 75 shot be ok? i see that alot of people here in this forum say that they use a 75 shot with no problems.
If you were running race gas then yeah. I wouldn't run 15psi on the 14B plus a 75hp shot on pump gas unless you ahve some serious tuning time behind you. Remember your 15psi will be 18psi when you spray (if not higher..)
